It is currently Fri Aug 08, 2025 9:41 am
 Post subject: Blanchard Truss Rods
PostPosted: Tue Dec 26, 2017 8:37 pm
First name: David
City: Napa
Zip/Postal Code: 94558
I'll definitely be using Mark Blanchards truss rods in the future. These are sweet and perfect and the welds don't make me wake up at 2am thinking haha
These users thanked the author dofthesea for the post: Hesh (Wed Dec 27, 2017 5:57 am)
 Post subject: Re: Blanchard Truss Rods
PostPosted: Wed Dec 27, 2017 10:44 am
First name: Danny
Last Name: Vincent
Nice! Who carries them David?
PostPosted: Wed Dec 27, 2017 11:55 am
You can order directly from Marks website.
PostPosted: Wed Dec 27, 2017 1:01 pm
"You can order directly from Marks website."
...and you should.
PostPosted: Wed Dec 27, 2017 11:09 pm
City: Escondido
Zip/Postal Code: 92029
What makes them special? I don’t worry too much about the welds in Martin rods, or the welds of Stew Mac hot rod truss rods. Should I? Is there something else that makes these special?
PostPosted: Thu Dec 28, 2017 7:35 am
Yes. Mark engineered the rods to use two different threads (TPI) creating a "gear like" action to adjustments. Very clever! You can or you could when I put 50 or so of them in my guitars turn them by hand with no wrench when inspecting them making for a very smooth action.
What I did not feel is resistance, resistance and then it breaks loose and moves too far. These rods won't do that..... These are smooth.
I'll add that these looked very much like the LMI rods back about 10 years go but not only did they work differently they're stainless too. I can't tell you how much truss rod corrosion I see on a daily basis often seizing up the rod. It's even standard fare on G*bsons when ever I work on one to remove the adjuster nut and lube it up to maintain serviceability into the future.
I'll also add that having used the similar looking LMI rods back in the day they had "weld globs" that were proud of the 1/4" dimension of the rods requiring anyone with a 1/4" truss rod slot like I used to file the weld globs off before use. No biggie but I never had to do this with Mark's rods.
And I'll also add one last thing. Luthiers, the working the trade ones are a community and we tend to try to support each other at times when we can. At least I do and have always done and will always do so. This is a superior product developed by one of us and as such I'm very inclined to support the innovation and my own community.
And really lastly Mark is a very nice guy and I consider him a friend. [:Y:]
PS: The Martin two way rod is superior too and if I was still building I would be using either of these two rods.
PostPosted: Sun Dec 31, 2017 4:22 pm
First name: David
City: Napa
And Marks customer service is top notch. When a high % of top Luthiers loves a particular product this typically equates to a great product. What I have been seeing quite a bit of over the years from other luthiers on the boards is Truss rod failure. so to me its a no brainer to just get the best one possible. The truss rod debate is kind of like the cheap tuner debate. Why on earth would ya want to put a cheap tuner on a nice hand built instrument.
PostPosted: Sun Dec 31, 2017 4:59 pm
...particularly when truss rods are so much harder to replace.
These users thanked the author Alan Carruth for the post: Hesh (Sun Dec 31, 2017 7:31 pm)
